Draw Menu (Mac OS X)
The Draw menu contains all of the SketchUp drawing tools and provides an alternative to using the tool palette or keyboard shortcuts.
Line
The Line menu item invokes a Line tool used to draw Line entities, or edges, within the drawing area.
Keyboard Shortcut: Apple+L
Arc
The Arc menu item invokes an Arc tool used to draw Arc entities, comprised of multiple connected straight line segments (editable as a single curve).
Keyboard Shortcut: Apple+J
Freehand
Use the Freehand menu item to invoke a Freehand tool used to draw irregular, coplanar connected lines in the form of Curve entities.
Keyboard Shortcut: Apple+F
Rectangle
The Rectangle menu item invokes a Rectangle tool used to draw four coplanar intersecting edges and a subsequent Face entity.
Keyboard Shortcut: Apple+K
Circle
The Circle menu item invokes a Circle tool used to draw Circle entities.
Polygon
The Polygon menu item invokes a Polygon tool used to draw regular Polygon entities, inscribed within a circle, consisting of 3 to 100 sides.
Keyboard Shortcut: Apple+;
